Today was a marathon work session. I started by wiring the AOA system flaps not up switch. Then I secured the flap drive motor wiring and installed a molex connector. Next I ran wiring for lighting for the baggage compartment and the electrical equipment compartment. Then I did a general wiring harness securing and tying especially in the elevator push tube tunnel under the cabin floor area. Following this I reinstalled the cabin and baggage area flooring I had removed to route wiring in the elevator push tube tunnel. Lastly I hooked up the wiring for the lighting for the baggage compartment and electrical equipment compartment and tested out the circuit. Everything was working well so I added clamps here and there to secure the wiring and ensure proper clearance between the wiring and structure so no wires would chafe.
AOA flaps not up switch wired
Flap motor wiring secured and a molex connector installed
